Api session event editor panel set excel
API Endpoint: editorpanel/set_excel.
Description: Set Excel Sheet
| 0 | REQUIRED | (PANEL Integer ID) | Panel | |
| 1 | REQUIRED | (EXCEL_SHEET Integer ID) | Excel Sheet |
| 200 | String (String) |
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_excel/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'JavaScript example POST:
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_excel/", options)
