Api session event editor panel import wikipedia points
Revision as of 13:38, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorpanel/import_wikipedia_points.
Description: Import Wikipedia Points
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorpanel/import_wikipedia_points/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ ]'
JavaScript example POST:
 body: '[ ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/import_wikipedia_points/", options)
