Api session event editor panel duplicate answer
API Endpoint: editorpanel/duplicate_answer.
Description: Duplicate Answer (Panel)
| 0 | REQUIRED | (PANEL Integer ID or multiple values in array [1, 2, 3]) | Panel | |
| 1 | REQUIRED | (Integer number or multiple values in array [1, 2, 3]) | Integer[] |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorpanel/duplicate_answer/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorpanel/duplicate_answer/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'JavaScript example POST:
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/duplicate_answer/", options)
