Api session event editor netline add
API Endpoint: editornetline/add.
Description: Add a Net Line with the provided Net Function
| 0 | REQUIRED | (NET_FUNCTION Integer ID) | Net Function ID |
| 200 | Integer (Net Line ID) |
curl 'https://engine.tygron.com/api/session/event/editornetline/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST:
body: '1'
fetch("https://engine.tygron.com/api/session/event/editornetline/add/", options)
