Api session event editor levee set top function
Revision as of 13:35, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorlevee/set_top_function.
Description: Set Top Function
0 REQUIRED (LEVEE Integer ID or multiple values in array [1, 2, 3]) Levee
1 REQUIRED (FUNCTION Integer ID or multiple values in array [1, 2, 3]) Function
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorlevee/set_top_function/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorlevee/set_top_function/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'
JavaScript example POST:
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorlevee/set_top_function/", options)
