Api session event editor global set query timing
Revision as of 13:34, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorglobal/set_query_timing.
Description: Set Query Timing
0 REQUIRED (GLOBAL Integer ID or multiple values in array [1, 2, 3]) Global
1 REQUIRED (Timing or multiple values in array [a, b, c]) Timing[]
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorglobal/set_query_timing/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "BEFORE" ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorglobal/set_query_timing/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "BEFORE", "AFTER", "AFTER" ] ]'
JavaScript example POST:
 body: '[ 1, "BEFORE" ]'
fetch("https://engine.tygron.com/api/session/event/editorglobal/set_query_timing/", options)
