Api session event editor geotiff add url
Revision as of 13:34, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorgeotiff/add_url.
Description: Add new GeoTIFF Item from Web URL.
0 REQUIRED (String or multiple values in array ["a", "b", "c"]) GeoTIFF Name
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Web URL
2 REQUIRED (String or multiple values in array ["a", "b", "c"]) Uploader
3 OPTIONAL (String or multiple values in array ["a", "b", "c"]) CRS Override (optional)
200 Integer[] (GeoTIFF IDs)
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/add_url/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "GeoTIFF Name 1", "Web URL 1", "Uploader 1", "" ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/add_url/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ "GeoTIFF Name 1", "GeoTIFF Name 2", "GeoTIFF Name 3" ], [ "Web URL 1", "Web URL 2", "Web URL 3" ], [ "Uploader 1", "Uploader 2", "Uploader 3" ], "" ]'
JavaScript example POST:
 body: '[ "GeoTIFF Name 1", "Web URL 1", "Uploader 1", "" ]'
fetch("https://engine.tygron.com/api/session/event/editorgeotiff/add_url/", options)
