Api session event editor geotiff add
Revision as of 13:34, 14 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorgeotiff/add.
Description: Add new GeoTIFF Item with provided file. For files larger than 2GB, use the Stream API or Web URL.
0 REQUIRED (String) GeoTIFF Name
1 REQUIRED (byte or multiple values in array [a, b, c]) File bytes (< 2GB)
2 REQUIRED (String) Uploader
3 OPTIONAL (String) CRS Override (optional)
200 Integer (GeoTIFF ID)
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "GeoTIFF Name", 1, "Uploader", "" ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "GeoTIFF Name", [ 1, 2, 3 ], "Uploader", "" ]'
JavaScript example POST:
 body: '[ "GeoTIFF Name", 1, "Uploader", "" ]'
fetch("https://engine.tygron.com/api/session/event/editorgeotiff/add/", options)
