Api session event editor geoplugin remove
API Endpoint: editorgeoplugin/remove.
Description: Remove existing Geo Plugin
| 0 | REQUIRED | (GEO_PLUGIN Integer ID or multiple values in array [1, 2, 3]) | Geo Plugin |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorgeoplugin/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorgeoplugin/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'JavaScript example POST:
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorgeoplugin/remove/", options)
