Heat Stress Module overview
Revision as of 14:13, 13 April 2026 by Frank@tygron.nl (talk | contribs)
The DPRA Heat Stress Module for the Heat Stress Overlay can be used for heat stress calculations, based on geographical features and locale parameters. The final result is the physiological equivalent temperature, which is a measure of temperature which takes into account factors which can change the experience and effects of temperature.
The module performs these calculations in accordance with the DPRA Heat stress report.
Input factors
The calculation of the Heat Stress Overlays takes into account:
Calculation of Physiological Equivalent Temperature
To calculate the Physiological Equivalent Temperature (PET), we first have to determine which formula (sun or shade/night) should be used. It is selected by:
PET sun
The following factors influence the Physiological Equivalent Temperature for locations directly in the sun:
PET shade and night
The following factors influence the Physiological Equivalent Temperature for locations directly in the shade or at night:
Required information
In order to configure the Heat Stress Overlay accurately additional data needs to be loaded in:
