Api session event editor weather add
API Endpoint: editorweather/add.
API Endpoint name is Api session event editor weather add.
Use this endpoint to Add a new Weather of a specified type.
| 0 | REQUIRED | (Enumeration) | Weather Type Effect | DROUGHT, FLOODING, NO_EFFECT, RAIN, SNOW or WIND |
| 200 | Integer (Weather ID) |
curl 'https://engine.tygron.com/api/session/event/editorweather/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"NO_EFFECT"'JavaScript example POST:
body: '"NO_EFFECT"'
fetch("https://engine.tygron.com/api/session/event/editorweather/add/", options)
