Api session event editor specialeffect add
Revision as of 12:01, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorspecialeffect/add.
API Endpoint name is Api session event editor specialeffect add.
Use this endpoint to Add new Special Effect
0 OPTIONAL (Point with crs: EPSG:3857) Location (optional)
1 OPTIONAL (PARTICLE_EMITTER Integer ID) Particle Emitter (optional)
200 Integer (Special Effect ID)
curl 'https://engine.tygron.com/api/session/event/editorspecialeffect/add/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "", "" ]'
JavaScript example POST:
 body: '[ "", "" ]'
fetch("https://engine.tygron.com/api/session/event/editorspecialeffect/add/?crs=3857", options)
