Api session event editor setting set import crs
Revision as of 12:00, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorsetting/set_import_crs.
API Endpoint name is Api session event editor setting set import crs.
Use this endpoint to Set Import Crs
0 REQUIRED (String) String
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_import_crs/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"Text"'
JavaScript example POST:
 body: '"Text"'
fetch("https://engine.tygron.com/api/session/event/editorsetting/set_import_crs/", options)
