Api session event editor parametric add example
API Endpoint: editorparametric/add_example.
API Endpoint name is Api session event editor parametric add example.
Use this endpoint to Add Example
| 0 | REQUIRED | (Enumeration) | Example | CITY_NEIGHBORHOOD, SUBURBAN_NEIGHBORHOOD, URBAN_NEIGHBORHOOD or WINDMILL_AREA |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorparametric/add_example/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"CITY_NEIGHBORHOOD"'JavaScript example POST:
body: '"CITY_NEIGHBORHOOD"'
fetch("https://engine.tygron.com/api/session/event/editorparametric/add_example/", options)
