Api session event editor panel set visible
Revision as of 11:58, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorpanel/set_visible.
API Endpoint name is Api session event editor panel set visible.
Use this endpoint to Set Visible
0 REQUIRED (PANEL Integer ID) Panel
1 REQUIRED (true, false) Boolean true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_visible/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'
JavaScript example POST:
 body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_visible/", options)
