Api session event editor netload set state
Revision as of 11:56, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editornetload/set_state.
API Endpoint name is Api session event editor netload set state.
Use this endpoint to Set State
0 REQUIRED (NET_LOAD Integer ID or multiple values in array [1, 2, 3]) Net Load
1 REQUIRED (TimeState or multiple values in array [a, b, c]) TimeState[]
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetload/set_state/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "NOTHING" ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editornetload/set_state/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "NOTHING", "WAITING_FOR_DATE", "REQUEST_PLOT_OWNER_APPROVAL" ] ]'
JavaScript example POST:
 body: '[ 1, "NOTHING" ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/set_state/", options)
