Api session event editor netload add
API Endpoint: editornetload/add.
API Endpoint name is Api session event editor netload add.
Use this endpoint to Add new Net Load
| 0 | REQUIRED | (Enumeration) | Net Type | ELECTRICITY, GAS, HEAT, INTERNET or SEWER |
| 1 | REQUIRED | (true, false) | Is root load | true or false |
| 200 | Integer (Net Load ID) |
curl 'https://engine.tygron.com/api/session/event/editornetload/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "ELECTRICITY", false ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editornetload/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "ELECTRICITY", true ]'JavaScript example POST:
body: '[ "ELECTRICITY", false ]'
fetch("https://engine.tygron.com/api/session/event/editornetload/add/", options)
