Api session event editor geotiff add
API Endpoint: editorgeotiff/add.
API Endpoint name is Api session event editor geotiff add.
Use this endpoint to Add new GeoTIFF Item with provided file. For files larger than 2GB, use the Stream API or Web URL.
| 0 | REQUIRED | (String) | GeoTIFF Name | |
| 1 | REQUIRED | (byte or multiple values in array [a, b, c]) | File bytes (< 2GB) | |
| 2 | REQUIRED | (String) | Uploader | |
| 3 | OPTIONAL | (String) | CRS Override (optional) |
| 200 | Integer (GeoTIFF ID) |
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "GeoTIFF Name", 1, "Uploader", "" ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "GeoTIFF Name", [ 1, 2, 3 ], "Uploader", "" ]'JavaScript example POST:
body: '[ "GeoTIFF Name", 1, "Uploader", "" ]'
fetch("https://engine.tygron.com/api/session/event/editorgeotiff/add/", options)
