Api session event editor geoplugin remove source
Revision as of 11:52, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorgeoplugin/remove_source.
API Endpoint name is Api session event editor geoplugin remove source.
Use this endpoint to Remove Source
0 REQUIRED (GEO_PLUGIN Integer ID or multiple values in array [1, 2, 3]) Geo Plugin
1 REQUIRED (SOURCE Integer ID or multiple values in array [1, 2, 3]) Source
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorgeoplugin/remove_source/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorgeoplugin/remove_source/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'
JavaScript example POST:
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorgeoplugin/remove_source/", options)
