Api session event editor geoplugin duplicate
API Endpoint: editorgeoplugin/duplicate.
API Endpoint name is Api session event editor geoplugin duplicate.
Use this endpoint to Duplicate existing Geo Plugin
| 0 | REQUIRED | (GEO_PLUGIN Integer ID or multiple values in array [1, 2, 3]) | Geo Plugin |
curl 'https://engine.tygron.com/api/session/event/editorgeoplugin/duplicate/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorgeoplugin/duplicate/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'JavaScript example POST:
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorgeoplugin/duplicate/", options)
