Api session event editor area remove relations
Revision as of 11:49, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorarea/remove_relations.
API Endpoint name is Api session event editor area remove relations.
Use this endpoint to Remove Relations
0 REQUIRED (AREA Integer ID) Area
1 REQUIRED (Relation or multiple values in array [a, b, c]) Relation[]
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorarea/remove_relations/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "OWNER" ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorarea/remove_relations/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ "OWNER", "CONSTRUCTOR", "DEMOLISHER" ] ]'
JavaScript example POST:
 body: '[ 1, "OWNER" ]'
fetch("https://engine.tygron.com/api/session/event/editorarea/remove_relations/", options)
