Api session event editor panel set template relation
API Endpoint: editorpanel/set_template_relation.
API Endpoint name is Api session event editor panel set template relation.
Use this endpoint to Set Template Relation
| 0 | REQUIRED | (PANEL Integer ID) | Panel | |
| 1 | OPTIONAL | (Enumeration) | Relation |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_template_relation/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "" ]'JavaScript example POST:
body: '[ 1, "" ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_template_relation/", options)
