Api session event editor panel set excel update timing
Revision as of 11:29, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorpanel/set_excel_update_timing.
API Endpoint name is Api session event editor panel set excel update timing.
Use this endpoint to Set Excel Sheet Update Timing
0 REQUIRED (PANEL Integer ID or multiple values in array [1, 2, 3]) Panel
1 REQUIRED (Timing or multiple values in array [a, b, c]) Timing[]
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_excel_update_timing/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "BEFORE" ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorpanel/set_excel_update_timing/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "BEFORE", "AFTER", "AFTER" ] ]'
JavaScript example POST:
 body: '[ 1, "BEFORE" ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/set_excel_update_timing/", options)
