Api session event editor panel edit answer event
Revision as of 11:29, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorpanel/edit_answer_event.
API Endpoint name is Api session event editor panel edit answer event.
Use this endpoint to Edit Answer (Panel) Event
0 REQUIRED (PANEL Integer ID) Panel
1 REQUIRED (Integer number) Integer
2 REQUIRED (true, false) Boolean true or false
3 REQUIRED (CodedEvent) CodedEvent
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorpanel/edit_answer_event/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, 1, false, {
 "id" : -1,
 "parameters" : [ ]
Curl example multi item POST:
[ 1, 1, true, {
 "id" : -1,
 "parameters" : [ ]
JavaScript example POST:
 body: '[ 1, 1, false, { "id" : -1, "parameters" : [ ]} ]'
fetch("https://engine.tygron.com/api/session/event/editorpanel/edit_answer_event/", options)
