Api session event editor netline insert point
Revision as of 11:27, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editornetline/insert_point.
API Endpoint name is Api session event editor netline insert point.
Use this endpoint to Insert a new Node in an existing Net Line, potentially splitting the Net Line into two parts. Also specify at what distance the new Nodes are merged with existing Nodes.
0 REQUIRED (NET_LINE Integer ID) Net Line ID
1 REQUIRED (Point 3D with crs: EPSG:3857) Inserted Node Point
2 OPTIONAL (Floating point number) Node merge distance (optional, default: 1.0m)
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetline/insert_point/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658720.5217981633, 6799405.633329327, -0.2 ]
}, 1.0 ]
Curl example multi item POST:
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658774.9076194018, 6799351.883097376, -0.68 ]
}, 1.0 ]
JavaScript example POST:
 body: '[ 1, { "type" : "Point", "coordinates" : [ 658720.5217981633, 6799405.633329327, -0.2 ]}, 1.0 ]'
fetch("https://engine.tygron.com/api/session/event/editornetline/insert_point/?crs=3857", options)
