Api session event editor indicator set parent
Revision as of 11:25, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: editorindicator/set_parent.
API Endpoint name is Api session event editor indicator set parent.
Use this endpoint to Set a parent Indicator for a specified Indicator. This will cause the specified Indicator to be a subselectable Indicator of the parent. It is not possible to set an Indicator which has a parent itself as a parent of another Indicator.
0 REQUIRED (INDICATOR Integer ID) Indicator ID
1 REQUIRED (Integer number) Indicator ID of parent (Indicator without a parent should have their parent Indicator ID set to -1)
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorindicator/set_parent/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST:
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorindicator/set_parent/", options)
