Api session event editor indicator set parent
API Endpoint to Set a parent Indicator for a specified Indicator. This will cause the specified Indicator to be a subselectable Indicator of the parent. It is not possible to set an Indicator which has a parent itself as a parent of another Indicator..
API Endpoint name is Api session event editor indicator set parent
| 0 | REQUIRED | (INDICATOR Integer ID) | Indicator ID | |
| 1 | REQUIRED | (Integer number) | Indicator ID of parent (Indicator without a parent should have their parent Indicator ID set to -1) |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorindicator/set_parent/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'JavaScript Example POST:
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorindicator/set_parent/", options)
