Api session event editor indicator export excel call tree
Revision as of 09:42, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Export Excel Sheet Call Tree.
API Endpoint name is Api session event editor indicator export excel call tree
0 REQUIRED (INDICATOR Integer ID) Indicator
200 byte[] (byte array)
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorindicator/export_excel_call_tree/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript Example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorindicator/export_excel_call_tree/", options)
