Api session event editor geotiff add
Revision as of 09:42, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Add new GeoTIFF Item with provided file. For files larger than 2GB, use the Stream API or Web URL..
API Endpoint name is Api session event editor geotiff add
0 REQUIRED (String) GeoTIFF Name
1 REQUIRED (byte or multiple values in array [a, b, c]) File bytes (< 2GB)
2 REQUIRED (String) Uploader
3 OPTIONAL (String) CRS Override (optional)
200 Integer (GeoTIFF ID)
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "GeoTIFF Name", 1, "Uploader", "" ]'
Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorgeotiff/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "GeoTIFF Name", [ 1, 2, 3 ], "Uploader", "" ]'
JavaScript Example POST:
 body: '[ "GeoTIFF Name", 1, "Uploader", "" ]'
fetch("https://engine.tygron.com/api/session/event/editorgeotiff/add/", options)
