Api session event editor building generate water connection
API Endpoint to Generate Water Connection..
API Endpoint name is Api session event editor building generate water connection
| 0 | REQUIRED | (FUNCTION Integer ID) | Function | |
| 1 | REQUIRED | (MultiPolygon with crs: EPSG:3857) | Area | |
| 2 | REQUIRED | (Floating point number) | Min Length | |
| 3 | REQUIRED | (Floating point number) | Max Length | |
| 4 | REQUIRED | (Floating point number) | Width | |
| 5 | REQUIRED | (Floating point number) | Large Road Area | |
| 6 | REQUIRED | (Floating point number) | Straight Distance | |
| 7 | REQUIRED | (Floating point number) | Max Height Difference | |
| 8 | REQUIRED | (Floating point number) | Ignore Upstream | |
| 9 | REQUIRED | (true, false) | Include Water Bodies | true or false |
| 200 | Integer (Amount of generated Objects) |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorbuilding/generate_water_connection/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, 85, 34, 65, 66, 83, 94, 16, false ]
'Curl Example multi item POST:
[ 1, {
}, 86, 97, 83, 40, 62, 58, 23, false ]
'JavaScript Example POST:
body: '[ 1, { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]}, 85, 34, 65, 66, 83, 94, 16, false ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/generate_water_connection/?crs=3857", options)
