Api session event editor area generate inundation areas
API Endpoint to Generate Inundation Area.
API Endpoint name is Api session event editor area generate inundation areas
| 0 | REQUIRED | (Floating point number) | Double |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_inundation_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '35'Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_inundation_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '47'JavaScript Example POST:
body: '35'
fetch("https://engine.tygron.com/api/session/event/editorarea/generate_inundation_areas/", options)
