Api session event editor address add
API Endpoint to Building Address belong to.
API Endpoint name is Api session event editor address add
| 0 | REQUIRED | (BUILDING Integer ID or multiple values in array [1, 2, 3]) | Building | |
| 1 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Street name |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editoraddress/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Street name 1" ]'Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editoraddress/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Street name 1", "Street name 2", "Street name 3" ] ]'JavaScript Example POST:
body: '[ 1, "Street name 1" ]'
fetch("https://engine.tygron.com/api/session/event/editoraddress/add/", options)
