Api session event editor address set point
API Endpoint to Set the point of an Address API Endpoint name is Api session event editor address set point
| 0 | REQUIRED | (ADDRESSE Integer ID or multiple values in array [1, 2, 3]) | Address ID | |
| 1 | REQUIRED | (Point with crs: EPSG:3857 or multiple values in array [a, b, c]) | Point |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editoraddress/set_point/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
"type" : "Point",
"coordinates" : [ 658781.504860215, 6799300.413463607 ]
'Curl Example multi item POST:
[ [ 1, 2, 3 ], [ {
"type" : "Point",
"coordinates" : [ 658708.3391533233, 6799335.82387388 ]
"type" : "Point",
"coordinates" : [ 658661.1027791698, 6799410.692479677 ]
"type" : "Point",
"coordinates" : [ 658767.6607241511, 6799442.960675782 ]
'JavaScript Example POST:
body: '[ 1, { "type" : "Point", "coordinates" : [ 658781.504860215, 6799300.413463607 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editoraddress/set_point/?crs=3857", options)
