Api session event editor specialeffect set location
Revision as of 09:12, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Set Location
0 REQUIRED (SPECIAL_EFFECT Integer ID) Special Effect
1 REQUIRED (Point with crs: EPSG:3857) Point
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorspecialeffect/set_location/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658711.5939220553, 6799383.215565693 ]
Curl Example multi item POST:
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658714.1227019535, 6799385.417873128 ]
JavaScript Example POST:
 body: '[ 1, { "type" : "Point", "coordinates" : [ 658711.5939220553, 6799383.215565693 ]} ]'
fetch("https://engine.tygron.com/api/session/event/editorspecialeffect/set_location/?crs=3857", options)
