Api session event editor setting set wind speed
API Endpoint to Set Wind Speed
| 0 | REQUIRED | (Floating point number) | Double |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_wind_speed/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '35'Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorsetting/set_wind_speed/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '59'JavaScript Example POST:
body: '35'
fetch("https://engine.tygron.com/api/session/event/editorsetting/set_wind_speed/", options)
