Api session event editor setting remove crs
Revision as of 09:11, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Remove Crs
0 REQUIRED (String) String
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorsetting/remove_crs/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"Text"'
JavaScript Example POST:
 body: '"Text"'
fetch("https://engine.tygron.com/api/session/event/editorsetting/remove_crs/", options)
