Api session event editor setting add crs
API Endpoint to Add Crs
| 0 | REQUIRED | (String) | String |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorsetting/add_crs/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"Text"'JavaScript Example POST:
body: '"Text"'
fetch("https://engine.tygron.com/api/session/event/editorsetting/add_crs/", options)
