Api session event editor parametric add
Revision as of 09:10, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Add new Parametric
0 REQUIRED (Enumeration) Alignment ROAD or SPACED
200 Integer (Integer)
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorparametric/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '"ROAD"'
JavaScript Example POST:
 body: '"ROAD"'
fetch("https://engine.tygron.com/api/session/event/editorparametric/add/", options)
