Api session event editor netline set net function
API Endpoint to Set the Net Function for a Net Line
| 0 | REQUIRED | (NET_LINE Integer ID or multiple values in array [1, 2, 3]) | Net Line | |
| 1 | REQUIRED | (NET_FUNCTION Integer ID or multiple values in array [1, 2, 3]) | Net Function |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editornetline/set_net_function/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editornetline/set_net_function/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]'JavaScript Example POST:
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editornetline/set_net_function/", options)
