Api session event editor netline add
Revision as of 09:08, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Add a Net Line with the provided Net Function
0 REQUIRED (NET_FUNCTION Integer ID) Net Function ID
200 Integer (Net Line ID)
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editornetline/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript Example POST:
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editornetline/add/", options)
