Api session event editor global set book value
API Endpoint to Set Book Value
| 0 | REQUIRED | (GLOBAL Integer ID) | Global | |
| 1 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder |
| 204 | No Content |
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorglobal/set_book_value/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'JavaScript Example POST:
body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editorglobal/set_book_value/", options)
