Api session event editor building generate water connection
Revision as of 09:03, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Generate Water Connection.
0 REQUIRED (FUNCTION Integer ID) Function
1 REQUIRED (MultiPolygon with crs: EPSG:3857) Area
2 REQUIRED (Floating point number) Min Length
3 REQUIRED (Floating point number) Max Length
4 REQUIRED (Floating point number) Width
5 REQUIRED (Floating point number) Large Road Area
6 REQUIRED (Floating point number) Straight Distance
7 REQUIRED (Floating point number) Max Height Difference
8 REQUIRED (Floating point number) Ignore Upstream
9 REQUIRED (true, false) Include Water Bodies true or false
200 Integer (Amount of generated Objects)
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorbuilding/generate_water_connection/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, 73, 36, 13, 3, 10, 22, 93, false ]
Curl Example multi item POST:
[ 1, {
}, 79, 61, 52, 48, 69, 55, 89, true ]
JavaScript Example POST:
 body: '[ 1, { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]}, 73, 36, 13, 3, 10, 22, 93, false ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/generate_water_connection/?crs=3857", options)
