Api session event editor area generate border areas
Revision as of 09:02, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint to Generate Border Area
0 REQUIRED (String) String
1 REQUIRED (String) String
2 REQUIRED (Floating point number) Double
204 No Content
Curl Example POST:
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_border_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Text", "Text", 87 ]'
Curl Example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorarea/generate_border_areas/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "Text", "Text", 12 ]'
JavaScript Example POST:
 body: '[ "Text", "Text", 87 ]'
fetch("https://engine.tygron.com/api/session/event/editorarea/generate_border_areas/", options)
