Api session event editor address set point
Revision as of 07:19, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set the point of an Address
0 REQUIRED (ADDRESSE Integer ID or multiple values in array [1, 2, 3]) Address ID
1 REQUIRED (Point with crs: EPSG:3857 or multiple values in array [a, b, c]) Point
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editoraddress/set_point/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658793.7021222798, 6799360.003671548 ]
Curl Example multi item POST:
[ [ 1, 2, 3 ], [ {
 "type" : "Point",
 "coordinates" : [ 658747.170623191, 6799325.176210491 ]
 "type" : "Point",
 "coordinates" : [ 658763.956069721, 6799365.8537382325 ]
 "type" : "Point",
 "coordinates" : [ 658742.3079597261, 6799426.581318164 ]
JavaScript Example POST:
 body: '[ 1, { "type" : "Point", "coordinates" : [ 658793.7021222798, 6799360.003671548 ]} ]'
fetch("https://development.tygron.com/api/session/event/editoraddress/set_point/?crs=3857", options)
