Api session event editor weather set trigger sec
API Event to Set whether the specified Weather's visualization Trigger automatically.
| 0 | REQUIRED | (WEATHER Integer ID) | Weather ID | |
| 1 | REQUIRED | (Floating point number) | Auto-Trigger (false means the Weather's visualization does not Trigger automatically) |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorweather/set_trigger_sec/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 83 ]'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorweather/set_trigger_sec/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 84 ]'JavaScript Example POST:
body: '[ 1, 83 ]'
fetch("https://development.tygron.com/api/session/event/editorweather/set_trigger_sec/", options)
