Api session event editor specialeffect set location
Revision as of 06:57, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Location
0 REQUIRED (SPECIAL_EFFECT Integer ID) Special Effect
1 REQUIRED (Point with crs: EPSG:3857) Point
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorspecialeffect/set_location/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658699.4323909846, 6799403.266979833 ]
Curl Example multi item POST:
[ 1, {
 "type" : "Point",
 "coordinates" : [ 658655.5693474981, 6799361.734979017 ]
JavaScript Example POST:
 body: '[ 1, { "type" : "Point", "coordinates" : [ 658699.4323909846, 6799403.266979833 ]} ]'
fetch("https://development.tygron.com/api/session/event/editorspecialeffect/set_location/?crs=3857", options)
