Api session event editor setting set wind speed
API Event to Set Wind Speed
| 0 | REQUIRED | (Floating point number) | Double |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorsetting/set_wind_speed/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '90'Curl Example multi item POST:
curl 'https://development.tygron.com/api/session/event/editorsetting/set_wind_speed/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '83'JavaScript Example POST:
body: '90'
fetch("https://development.tygron.com/api/session/event/editorsetting/set_wind_speed/", options)
