Api session event editor panel set visible
API Event to Set Visible
| 0 | REQUIRED | (PANEL Integer ID) | Panel | |
| 1 | REQUIRED | (true, false) | Boolean | true or false |
| 204 | No Content |
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorpanel/set_visible/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, false ]'JavaScript Example POST:
body: '[ 1, false ]'
fetch("https://development.tygron.com/api/session/event/editorpanel/set_visible/", options)
