Api session event editor panel set template relation
Revision as of 06:55, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Template Relation
0 REQUIRED (PANEL Integer ID) Panel
1 OPTIONAL (Enumeration) Relation
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorpanel/set_template_relation/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "" ]'
JavaScript Example POST:
 body: '[ 1, "" ]'
fetch("https://development.tygron.com/api/session/event/editorpanel/set_template_relation/", options)
