Api session event editor panel remove overlay
Revision as of 06:55, 10 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Remove Overlay
0 REQUIRED (PANEL Integer ID) Panel
204 No Content
Curl Example POST:
curl 'https://development.tygron.com/api/session/event/editorpanel/remove_overlay/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
JavaScript Example POST:
 body: '1'
fetch("https://development.tygron.com/api/session/event/editorpanel/remove_overlay/", options)
